Home > In Car Electronics (L405) > DIY Apple CarPlay install L405
Kev the Rev
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
@E500 thanks for showing this, I went ahead and got the same unit from Ebay for £183. I was dreading installing because I hate doing jobs that involve removing trim it but things went pretty much according to plan. A couple of items to snag still
The first is that I fitted it behind the glove box but it keeps fouling the glovebox when closed so I might reposition it up under the vents as you did.
@PhillV8S, the second issue is that I have had the unit running and after a bit of playing around with the dip switches it seemed to be working OK. The instructions say switch on number 2 but the other option is 1 and 2 together or third option is 5.
In the first two options the Car Play screen had an overlay of the original GPS so I tried switch 5 and that works fine except for the fact that I can't use the backwards and forwards steering wheel controls, the volume on the steering wheel works. Did you manage to get yours sorted?
Anyone else have any suggestions?
Post #705844 1st Dec 2024 6:43pm
PhillV8s
United Kingdom 2013 Range Rover Vogue SE SDV8 Aintree Green
I didn’t resolve the issue of not being able to skip tracks on Spotify via the steering wheel but not the end of the world pressing skip via the screen. I did try connecting via Bluetooth rather than Aux but didn’t make any difference for me. 2013 SDV8 4.4 Vogue SE Aintree
Post #705848 1st Dec 2024 6:57pm
Kev the Rev
Thanks, you took the words out of my mouth, it's not the end of the world and it's still way better than the original RR system
Post #705855 1st Dec 2024 8:15pm
LiKuid
Greece 2017 Range Rover Autobiography TDV6 Corris Grey
How do you guys find the microphone quality on phone calls on these devices?
I ve installed a couple of android devices in the past for my previous vehicles and both were far from perfect when making calls. It definitely depends on the microphone's placement, but i think it would be much better replacing the provided microphone with a hihger quality one with a windstopper.
Where do you place the microphone on the L405?
Post #706369 8th Dec 2024 8:03am
E500
I've managed to get mine to use the car's Bluetooth (and microphone) so it's fine for me; same as the OEM.
But it seems like perhaps not all of these units have the same options? Next time I drive the car I'll take some pics of the settings I'm using.
Post #706458 9th Dec 2024 11:21am
E500
This is how mine looks.
Setup -> Audio Settings -> then you have the Bluetooth / mic options
Post #706548 10th Dec 2024 1:40pm
iand
United Kingdom 2015 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Hi.
I'm considering one of these as I'd like a unit that can use the OEM mic and that has minimal wiring into the head unit i.e. no 3.5 jacks or similar. As far as I can tell this one would only need the wifi antenna locating somewhere and maybe an additional USB, maybe in the glovebox?
Looking at the comments on Amazon it sounds like some people managed to get the buttons to work and didn't lose any functionality. Has anyone else installed this unit and had better luck on the standard features not "vanishing" at all please?
Post #718175 19th May 2025 2:42pm
Simon181263
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
How was the sound quality, does the sound for Spotify etc still route through the original amp etc.
Post #722060 30th Jul 2025 6:16am
