Home > Technical (L322) > [L322]ZF 5HP24 Transmission failure ?
mistersam68
France 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hello,
I'm owning an 2003 L322.
I had issue with the torsen diff, so changed the full transfer box.
Now I'm stuck in two new issues.
-> changing from HI to Lo and opposite is ok (new TB motor mounted) but if I shut down the L322 with the Lo engaged, it never come back to life, I need to disconnect battery, manually place TB and servo to Hi position and then start again everything.
If any idea about this issue ...
-> Biggest issue, I was running safely last saturday (except the above issue but more doing offroading so Lo most of the time ..) but on Sunday suddenly the gearbox stop working ....
If I start from fresh, the 1st gear is not engaging then if I rev it a little bit when reaching around 1800 rpm it's like a big choc into the transmission (and a valve is changing at this exact moment seen with Icarsoft) then the transmission shift to 5th gear and say limp mode... during TB changing I tooked the time to change oil and filter for the GB, any idea about the origin of my issue ?
I can do this with Drive or Manual, I have the same effect ...
Thanks for your idea,
MrSam
Post #722031 29th Jul 2025 2:52pm
mistersam68
Hi all,
little update, on the gearbox issue, I think I found the explanation :
https://www.jaguarforums.com/forum/xj-xj8-...nfo-88369/
hoping the A drum is still alive,
no news for the TB issue
Post #722083 30th Jul 2025 11:08am
