Home > Technical (L405) > L405 DPF pressure sensor I can not find anywhere
hippy16
United Kingdom 2017 Range Rover Vogue TDV6 Carpathian Grey
I had my DPF cleaned and the mechanic said I needed a new DPF pressure sensor. After ordering two from different LR dealers of which said it is what is fitted to the vehicle and being wrong I decided to post here. The sensor part number is FoMoCo DC3A5L200CA. It is on my L405 TDV6, I have searched this part and the only ones that come up are Chinese replicas. I have included two photos below. Maybe this is on another engine? LR have provided two parts that they say it should be and it certainly isn’t the below. Help greatly appreciated.
Post #722144 31st Jul 2025 5:56pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
I recently replaced the differential pressure (DP) sensor on the DPF of my TDV6. It was a genuine Land Rover item and cost about £120 from one of the online dealers. Can't remember the name but I could find out if it would help. The number on the sensor is C2Z31296. As far as I know this is the only pressure sensor on the DPF but I'm happy to be proven wrong .
Cheers
Pete
Late extra. it was Maltings 4X4 and the number is: LR122713
Post #722149 31st Jul 2025 9:20pm
Faultlineshaun
Hi Hippy16,
Did you have any luck sourcing the correct part? I am currently in the same situation and am starting to go mad!
Kind regards,
Shaun.
Post #723714 31st Aug 2025 6:49pm
