![]() | Home > Technical (L405) > Twitchy body |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1518 ![]() ![]() |
I don't see a C1049-63 error code in the manual, only these 2:
911r44 Member Since: 30 Oct 2022 Location: Nottingham Posts: 18 ![]() ![]() |
Thank you fisha
The fluid tank is viewed as a serviceable item because of its filter … can’t remember the mileage to change it at though. 80k miles rings a bell. V8 or else ... |
An update regarding the active roll issue.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
I’ve personally not had much experience with valve blocks at all luckily. However when my first 405 was quite young there was a TSB re changing the valve blocks. This was an end result after changing most other hardware after complaints of knocking suspension. Can you confirm whether yours was ever changed?
Hello
Have you asked if the TSB is still live? I guess it will be… Then they can do the job for you FOC… |
Hi all
