![]() | Home > Technical (L322) > Slipping under hard accelleration |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1036 ![]() ![]() |
The rear stator bush seals the hydraulic feed circuit to the E-clutch so only affects 4th, 5th and 6th gears.
BIGDAWG Member Since: 05 Aug 2025 Location: Windsor Posts: 4 ![]() ![]() ![]() |
First I would like to say thank you for responding in a timely manner. I was not expecting you to respond so quickly. I am star struck right now, you are like a legend!
Thought I should also include a picture of the fluid I received. Does this look okay to you?
Also regarding the RR storing codes I have had a code in the past for "incorrect gear ratio", but it is not there currently. It was intermittent before the fluid change but has gone away now. Problem still persists though. |
Just for the avoidance of doubt, the most critical thing when setting the fluid level is that the engine is ticking over while the level is being set. If the engine is turned off, the fluid in the torque converter will immediately drain down into the sump and produce an artificially high fluid level. If you remove the filler/level plug when the engine isn’t running, you should get a litre of fluid down your arm.
