Home > In Car Electronics (L322) > L322 touch screen with phantom/random screen inputs!
Turbostars36
England 2011 Range Rover Autobiography 5.0 SC V8 Sumatra Black
Hi,
My L322 touch screen has been working fine then all of a sudden I am getting random/phantom inputs as if I am touching the screen. So for example I select a radio station then a few seconds later it will randomly start selecting other channels etc. Same thing on the phone menu etc.
Can someone please help guide me in the right direction. Is this a screen problem or something dreaded lurking in the boot?
Thanks in Advance.
James
Post #722473 7th Aug 2025 2:10pm
check that boot area for moisture first ... - .- -.
Post #722477 7th Aug 2025 3:07pm
Turbostars36
Thank you. No moisture or evidence of corrosion on modules in boot but I noted the rear tailgate rubber seals were replaced before I got it.
Post #722484 7th Aug 2025 4:24pm
Turbostars36
If it is not the touchscreen might it be something else? I’m thinking about replacing the head unit but concerned the problem could be elsewhere or is this unlikely based on the symptoms?
Post #722890 15th Aug 2025 7:34am
