Home > Maintenance & Mods (L405) > Changing instrument layout
Field100
Canada
Hello, loving the forum very informative UK transplant to Canada.
I have a 2017 L405 Autobiography 5.0 SC North American spec not sure if that's any relevance.
I'm trying to find away to switch the position of the tacho and speedo on the instrument display.
i don't know if the positioning can swapped with the Speedo in the right and tacho on the left. I've noticed that UK/European RR have it this way so not sure if its a NA thing or not.
Any help or input either way is apricated.
Post #722490 7th Aug 2025 5:50pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
I don’t think it’s possible to switch the positions of the speedometer and tachometer. The layout might vary just between the UK and other regions. On mine, the only available options are either the speedometer alone in the center, or the speedometer on the left and the tachometer on the right.
Post #722516 8th Aug 2025 9:45am
adara
You could try switching the settings to UK and see what happens
Post #722517 8th Aug 2025 9:45am
Field100
Canada
Hi Adara thanks I’ll give that a try and see what happens.
Post #722589 9th Aug 2025 2:57pm
