Home > Technical (L322) > 2010 4.4tdv8 stalling
JamesH4.4_tdv8L322
England 2010 Range Rover Vogue SE TDV8 Nara Bronze
Hi all, looking for some ideas on this problem.
RR has developed a fault where it will stall - completely cutting the engine (and power steering brakes etc!). It brings up the red restricted performance message but nothing else to give any clue what’s happening. Once stalled it will restart but cuts out after 2 seconds. If left for about 30 minutes it will restart and drive ok. It will restart if I connect my basic OBD reader and clear all codes.
Based on codes and their knowledge my local independent garage have changed the crank sensor and a MAF sensor. Unfortunately no change in the symptoms at all.
The stalling seems to happen after driving for about 40 minutes or equivalent e.g. a 25 min journey after an earlier (2hrs previously) 25ish minute journey. Shorter isolated journeys haven’t triggered this stalling (yet). This is making me think the problem is temperature related.
There’s no misfire or indication of an engine or other mechanical fault when the stalling happens.
Codes from my basic reader and the local garage haven’t given any clear indication of anything that would cause a stall.
I’m leaning towards it being an electrical / wiring / sensor fault mostly because the car seems able to be reset by simple code reading and trouble code deleting. But how to track it down?
Any ideas?? I have tried to search thoroughly and only found one very similar thread which was a crank sensor problem.
Thanks in advance, James
Post #716375 18th Apr 2025 10:02pm
JamesH4.4_tdv8L322
A few screenshots of codes that have been recorded through this process
Post #716389 19th Apr 2025 10:15am
Mikey
Throttle body sticking shut? Seen a few of them, and they don't log any codes for some reason...
Starts and runs for a few seconds, cuts out and won't restart, barely even a cough. Let it sit for 10 secs, and it does the same
Post #716390 19th Apr 2025 10:45am
JamesH4.4_tdv8L322
Thanks smiley, that sounds very like the symptoms - especially not producing codes.
My garage told me they had the same ideas but investigated and couldn’t see anything obviously wrong (no gunk or wear in it).
With how much cost and inconvenience it’s been causing me I might just get the whole part replaced. I assume that’s going to be the fix?? Or could it be some weird ECU issue telling it to close??
Post #716391 19th Apr 2025 10:58am
JamesH4.4_tdv8L322
Mikey not Smiley! Sorry, autocorrect got me
Post #716392 19th Apr 2025 10:59am
JamesH4.4_tdv8L322
After driving now for several months with zero problems I can confirm that replacing the throttle body solved this stalling problem.
If you have these symptoms I’d suggest buying one for the £250 ish they cost and fitting yourself.cit is not much more than four bolts and a couple of clips and it’s right in front of you as you look at the engine.
I spent waaaay more in garage hours and unnecessary replacement parts than I needed to.
Post #722493 7th Aug 2025 6:33pm
Alfie boy
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Zambezi Silver
Just wanted to say thank you for the up date, i am sure it will help someone in the future.......might even be me Laughing
Post #722496 7th Aug 2025 7:53pm
