Home > Technical (L322) > Power steering fluid leak - coil cooler replacement
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Came to fire up the Rangie after being away on a trip for a few weeks and pow - heavy steering. The Rangie had dumped a load of power steering fluid all over the garage floor. I decided to roll up my sleeves and fix the old girl, first thing to do was to find where the fluid was leaking from. Not easy with the car fully assembled, so I started by reading up on some old threads here for ideas before getting stuck in. The Powerful UK youtube video where they strip the front end of an L322 for a facelift was also helpful:
Still more to come off, including slam panel and the lower support sheetmetal:
After about four hours (I was going slowly, not taken the front end apart before so was learning as I went), I got to this point, where I could see clearly that the fluid was leaking from the 'coil cooler' power steering radiator - the small, thin radiator with the leaves lodged at the top:
Time for a new one, from Keith Gotts who are pretty local. Cost was about £160 including VAT for the part:
I invested in a pair of Knipex hose clamp pliers, as the spring steel clamps on the hydraulic hoses were tricky to get off with the pliers I had. The Knipex ones are the dog's danglies, expensive at £48 but well worth having for this job and all the future ones:
New coil cooler installed and leak checked. At least this new one is painted, it might last longer than the old one. Interestingly I checked the car's service history and it had already had one replacement coil cooler at 41,000 miles, when RRUK owned the car. It's now at 154,000 miles, so this last coil cooler lasted fairly well by comparison. It sits out front in all the road spray and salt, no surprise they corrode and eventually leak. The hydraulic system needed about 1.2 litres to top back up:
Work in progress:
And all back together, after about eight hours labour - should be about half this time next time round:
The failed coil cooler on the bench:
It was leaking from the upper pipe, at the bend; probably from a corrosion pin-hole:
Hope this write up helps if you end up replacing yours. I think a garage would charge about four hours labour on this job, so worth doing yourself if you can.
fanders
Post #469643 22nd Feb 2018 1:02am
cg2025cg
England 2009 Range Rover Vogue TDV8 Santorini Black
Hi,
Looking to do this job myself. workshop manual seems to think you've got to remove the radiator to get at the connecting pipes but it doesn't look like you've had to do that? where exactly do the pipes meet the cooler? also are they secured on with jubilee clips or anything like that? can't seem to get a definitive answer anywhere but id rather not have to bleed all the coolant and remove the radiator if I can avoid it. I also assume it's possible to get at everything without removing the bumper and just taking off the grille to get the fan out? more detail would be much appreciated!
Post #722560 8th Aug 2025 9:39pm
fanders
Hi, I didn't need to remove the radiator, the pipes that connect to the coil cooiler are accessible from underneath the car. From memory the pipes are a push fit over barbs on the pipe end and secured with a normal spring clamp, which is easy to remove with hose clamp pliers like the Knipex ones in my post. I think you'd struggle to access the coil cooler without removing the bumper and fan as shown.
I know when David Hallworth did this job on his TDV8, new coil coolers were on back order so I sold him my new-ish one from my TDV8 as I'd scrapped it by then and bought the 4.2SC. Given the corrosion-induced leak, it's best to fit a new coil cooler than a secondhand part.
fanders
Thumbs Up ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #722677 11th Aug 2025 10:26am
cg2025cg
Hi,
Thanks for the reply given the age of the post! Unfortunately I'm having to go with a second-hand part as these things, like most L322 parts, are like gold dust trying to find new. I've had no luck nor has my Indy garage (who wanted to charge 7hrs labour for this job at £800). I did a pre-emptive strip down of the front end to make sure I could access everything and the only thing I had an issue with was the front radiator fan just in front of the cooler. I'd taken off the bumper, top metal panel with the bonnet latch screwed into it (not sure of name) and both headlights etc. The fan unit seemed like it should just unclip from its plastic bits and slide upward but i'm wondering if (and how) I should remove that big piece of metal (slam panel?) sitting at the front of the car behind the bumper. Didn't want to wiggle the fan too much as it was hitting the radiator fins. It looks like you've done this from your pictures so I hope it's just a few bolts and the fan can be pulled away? Thanks!
Post #722685 11th Aug 2025 12:49pm
fanders
Yes I removed the slam panel (horizontal sheet metal panel at the front top, which the bonnet closes on to) and also the heavy crash bar at the front to provide access. From memory they were just bolted in, no particular issues removing them.
fanders
2021 Hilux 2.4
Post #722692 11th Aug 2025 2:31pm
