![]() | Home > Technical (L322) > Kill switch question |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 293 ![]() ![]() |
An interesting question. I don't know but one imagines that eventually there wouldn't be sufficient flow and pressure for the low pressure pump so it would throw a P0087 or similar and go in to limp/restricted performance.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1418 ![]() ![]() |
Diesel also acts as a lubricant in the HP pump and possibly it would eventually damage it. 2018 SE SDV8 4.4 Byron Blue |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
Got the central console apart at last. A switch on the brake sensor earth would prevent starting and this is buried under the dash. Also the earth to the gear selector woud stop it being moved although I still don't like the idea of the engine being started so may do this as a backup. After some research the main weakness once anyone gets in the is the OBD socket as it's easy to create a new key so this will be also moved and made inaccessible. 2012 TDV8 Vogue (L322) |
