![]() | Home > Technical (L322) > Battery Values / Charging |
| RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 262
I'm no expert, but mine shows 14.4v on the move, dropping to 13.7v when the random 'charging fault' rears its ugly head! 2011MY 4.4TDV8 Autobiography Baltic Blue
Should be 14v + upto 14.6v but if it drops when you run it with current draw, ie both heated screens on & blowers on and lights then after 20 seconds ish… If it does not recover to charge at high 13v on test I’d bin the Altenator sir… |
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 851
I see between 14.4 and 14.7v in current weather in my MY11 4.4
| steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 64
The fact that it would not even 'click' or 'whirr' suggests to me:
| Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 147
As Steve suggests, I would check and clean connections. Check and clean also the plug connection for the BMS - the little black connector (2 blue wires) attached to the negative battery connection. I did this having first disconnected the negative battery terminal. Following reconnection, perform a BMS reset.
| All times are GMT |
