![]() | Home > Technical (L322) > howling / frequency noise at motorway speed |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3380 ![]() ![]() ![]() |
Rad fan cutting in to aid cooling during a DPF regen? 2012 TDV8 Vogue (L322) |
Jimnic007 Member Since: 13 Aug 2019 Location: Cheshire Posts: 77 ![]() ![]() ![]() |
Could be, it certainly felt like something was whirring away at a high speed. Is that normal and anything to worry about? |
Not normal as there should be plenty of airflow at M-Way speeds through the radiator without needing fan assistance. Maybe worth investigating further. 2012 TDV8 Vogue (L322) |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1428 ![]() ![]() ![]() |
A similar noise on my L405 was diagnosed as a wheel bearing in need of replacement. Only Range Rovers since 1988 |
steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 63 ![]() ![]() ![]() |
It's a 5.0 petrol? so if I'm correct there is no regen on petrol cars? Sounds like viscous fan is getting tired. At higher RPM if its starting to get 'tired' it may be unable to keep slipping. However, if you are using the A/C first check that the electric cooling fan at the front is working Current: 2003 TD6 HSE 2004 Vogue SE 4.4 Previous: 1993 Classic 3.9 |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
Some folk find a droning noise comes from an aged scuttleboard
Thanks all, I will investigate the suggestions above.
