![]() | Home > Technical (L322) > Remote locking problem |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8794 ![]() ![]() ![]() |
Under the spoiler at the top of the upper boot lid is a plastic box that looks similar to an old music cassette tape, this is the aerial for the central locking...
noblerover Member Since: 12 Apr 2019 Location: Coventry Posts: 9 ![]() ![]() ![]() |
Amazing! Why did they put it there? That totally fits with the issue I'm experiencing. Out with the soldering iron it is! Thank you so much for that piece of information. |
Location and close up....
Thank you. Massively helpful. I'll have a chance to look at it next week. I'll post to let you know how I get on. |
So further investigation this evening. I have managed to find both ends of the aerial wire and isolated it and test it for continuity both end-to-end and from the center cable to the shielding and all is fine. I've had the modulate itself out and taking it apart and can see no water staining but as there is power to the module I have to conclude that the modulate itself is at fault. I've ordered a replacement let's see if it makes a difference. |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 825 ![]() ![]() ![]() |
i have had my RR 8 years and had locking problems for ever.
Interesting. What year was the l322 you had problems with? |
2005
Final update: Its fixed! I tried a replacement box but nothing changed. So out with the RAVE wiring diagrams expecting things to get complicated. It couldn't have been simpler. There are three connectors to the box, the aerial lead that goes to another box in the passenger side boot, a 2 wire lead that connects to the rear window element, and a three wire connector. This has a power supply from the rear fuse box, a signal wire to the BCU and a signal wire to the audio system. The first wire I tried was the power feed and, hay presto, no voltage. The fuse was good, so a bit more testing revealed a broken wire in the tailgate rubber gaiter. New wire spliced in, remote key function restored.
great RR 2005 4.4 petrol
