|  | Home > Maintenance & Mods (L322) > Chassis Rail Issue |
| TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 439      | L322s are monocoque, they don’t have separate chassis that you can place an axel stand under. You need to use one of the four jack points, rear subframe mounting points or on the other very specific locations described in the workshop manual - have you checked out the wiki? 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
|  16th Aug 2025 5:49pm |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | hope this helps, and lots more info is on the forum  ( use the search - thats what it is there for)   | ||||
|  16th Aug 2025 6:30pm |
| Jonester Member Since: 16 Aug 2025 Location: North Yorkshire Posts: 10      |
 Between forums and YouTube videos there must be well over 30 different THE “definitive” way to place axle stands on an L322 with acrimonious debates over the various approaches, never seen anything like it. But I guess that’s Range Rovers. I’m thinking the simplest way is to jack from the front/Rear and place stands on the jacking points. Not seen the wiki but now that someone has pointed out the search feature I’ll have a look for it. Thanks for the tip. | ||
|  17th Aug 2025 6:57am |
 I was looking for a search box, don’t realise it was just just just “click on the word search”. lol And thanks for the diagram, that’s helps massively. So I guess when I’m seeing people jacking from the front and the rear to save jacking each side independently this isn’t an “official” jacking point. lol | ||||
|  17th Aug 2025 7:01am |
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836      | What you see in the diagram above is the official way because you’ve seen what can happen when you use the ‘chassis’ rail as an axle stand support….. ______________________________
|  17th Aug 2025 7:14am |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | The Sealey trolley jack you have needs the correct shaped adapter to fit into the rectangle shape jacking points on either side of the car, if you don't - then its very easy to move and create more damage
|  17th Aug 2025 9:50am |
 Quite. And I’m definitely learning that there are lots of people posing as Range Rover experts on social media who haven’t got a clue what they’re talking about: the recommendation for jacking/axle stands on the “chassis rail” is pretty widespread. | ||
|  17th Aug 2025 3:29pm |
 This is how my trolley jack came as standard. That ok or wrong shape? | ||||
|  17th Aug 2025 3:33pm |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | your Sealey trolley jack is fine, all trolley jacks use that style of pad, but it  really needs an adapter, basically something made of metal that slips over the trolley jack and the rectangular bit at the top is shaped to seat properly into any of the jacking points on the car
|  17th Aug 2025 3:46pm |
| Posting Rules
