Home > Maintenance & Mods (L405) > L405 Seat Swap Nightmare
ChrisK
United Kingdom 2015 Range Rover Vogue SE SDV8 Mariana Black
Hi,
I have a 2015 L405 Vogue SE and decided to swap out the front and rear seats.... I hopped on eBay and found a front and rear set that were in fantastic condition for a great price, so I purchased them.
The purchased seats were from a 2017 L405 Autobiography and not surprisingly I'm having trouble getting them to work. The heating and cooling options on both front seats work, but using the controls to move the seats only works very intermittently and only the horizontal control shows any signs of life.
I've purchased a number of different seat control modules in an attempt to resolve the issue but no luck so far. I've also purchased the 16,000 page "Range Rover L405 (2014-2019) - Service Manual - Wiring Diagrams" document, the wiring diagram section for the seats is 40 pages long, but it doesn't show detail in relation to the pin layout for the seat control modules.
A friend, who is an auto electrician believes we need to move/swap/re-pin one/many cables in the Local Interconnect Network (LIN) bus and possibly in the Controller Area Network (CAN) bus as well.
So, that's the background information. I am wondering if anyone knew where I could get any information relating to the seat control module connector pin layout.
Many thanks in advance,
Chris
Post #722945 16th Aug 2025 4:44pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Has the seat module been coded to your car?
They store the vin in the module and it will need re coding for a start.
Post #722946 16th Aug 2025 5:13pm
ChrisK
Thanks for the information, really appreciate the help.
The 2017 seat modules haven't been coded to the vehicle/VIN. Do you know where I could take them to be coded?
Many thanks, again.
Post #722947 16th Aug 2025 5:35pm
zenman63
Do you have a G3iid gap tool?
Post #722948 16th Aug 2025 5:51pm
zenman63
I take it your original seat modules don’t fit?
Problem also your on the change over date.
I would try and get your old seat module to work on the new seats.
Post #722951 16th Aug 2025 6:01pm
ChrisK
I haven't got a G3iid gap tool, I'll take a look online and see where I can get one.
Thank you for your advice regarding using the original modules. Would you then perform a full reset on the original 2015 seat modules?
Many thanks.
Post #722957 16th Aug 2025 7:17pm
Sure I've read that they work on different can bus types and you can't make the early Range Rovers accept the later seats....
Hope I'm wrong.... Thumbs Up Pete
-Click here for Thread-
Post #722961 17th Aug 2025 12:13am
ChrisK
I contacted Land Rover and was told that it is possible, but some "tweaking" (as they put it) would be required with the wiring. I've done quite a bit of digging online and it was suggesting the same.
The 40 pages of seat wiring diagrams look as though it's possible. The fact I can move the seats horizontal position with the seat controller and the heating and cooling options both work is giving me some hope.
Thank you for your feedback, on this occasion I hope you're wrong Very Happy
Post #722970 17th Aug 2025 9:14am
That's good news, can you share how it's done when you sort it out... Cheers... Thumbs Up Pete
Post #722974 17th Aug 2025 9:41am
ChrisK
Hi Pete, absolutely! It's back from the paint shop early next week and we'll be cracking straight on with it, once we're up and running I'll share info/photos.
Post #722975 17th Aug 2025 9:45am
5c0tty
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi Chris
you say yours is a 2015 car, do you know what year the seats came from?
Scott
Post #723811 2nd Sep 2025 12:20pm
JamboM3
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Indus Silver
Would the simpler route not to swap the covers/cushions/trims over? Or was it a problem with that which made you go for the new ones?
Post #723813 2nd Sep 2025 1:46pm
