Home > Technical (L322) > 2010 L322 MS CAN bus down
jimboy
United States 2010 Range Rover HSE 5.0 V8 Nara Bronze
Had my 2010 L322 5.0 NA in the garage for about 6 weeks - I was replacing the front coolant pipe but I was delayed when I snapped some plastic. When I reconnected the battery to wake her up, I got a black instrument panel except for "smart key not recognized." It'll turn on and run just fine on the second press of on/off when I hold the key in the emergency position, but IPC is blank, TFT is blank. At first I was sorta excited - finally, a reason to get a proper scan tool!
IID BT G3 showed up and gave MS CAN codes from the IPC and the CJB (BCM), Both units gave U0010-88 MS CAN "bus off" codes, and the IPC also gave a U0018-00 MSCAN bus (-) shorted to bus (+). NONE of the modules on the MS CAN are showing up when scanning for ECUs [except those which are scanned via HSCAN, i.e. ICP and BCM]. Patrick at GAP suspects a wiring issue, probably water ingress he thinks. I've got access to a proper shop manual and wiring schematics, connector views and pinouts, etc.
So far, I've searched the forums and I've read the posts of buck66, kevrobbo1961 and Stuart-. I checked the location near the parking aid module in buck66's post, but my yellow/white yellow/blue twisted pair drops straight down in a big bundle and doesn't go around the metal bracket that cut into his wires.
When I check resistance at the diagnostic socket on pins 3 and 11, I get 59.9 or 60.0 ohms. When I check resistance to ground (passenger's footwell was handy, and looks shiny brand new, all dry down there btw) from either pin 3 or 11, I get open circuit. I think this means that the spine wiring of the bus is healthy, both 120 ohm terminal resistors are being seen from the diagnostic socket, and also that the two connectors which are in series with the spine of the bus - the driver's and passenger door connectors at C0322/C0463 and C0336/C0459 - must also be intact and healthy.
So what's the move? My thinking right now is that since the wiring seems OK, I should be looking for a faulty module, just "unplug and chug". Since mine wasn't fitted with the Companion cam, there's only 16 possible modules that could be at fault Rolling Eyes . Does anyone have a suggestion of where to check first, or of other electrical measurements I can make? In the absence of any likely suspects, I'll probably go in order of ease of removal.
Other possibly relevant info: a couple days prior to garaging it for the coolant pipe repair, I had noticed the rear passenger door refusing to electrically lock/unlock from either key fob button presses, nor central lock button. Manual lock/unlock was OK. The AC had also just began operating at reduced capacity, not getting very cold - prior it had always worked perfectly. I had checked pressures in the garage just before the coolant repair and they seemed normal. If the CAN bus issue was caused by water ingress, I think condensate drainage from the evaporator would be the mostly likely source.
Post #693353 26th May 2024 1:54pm
jimboy
After a closer look at the MS CAN wiring diagram, I decided to use the driver's and passenger's door connections to try to isolate the network, and now things are narrowed down a bit more.
Unplugging the driver's door electrical connector (in the flexible rubber boot in the door hinge where it meets the body) detaches the IPC and the diagnostic socket from the rest of the MS CAN system (and removes the driver door module from the MS CAN entirely). If testing this had fixed everything, it would imply my IPC or wiring nearby was the source of the CAN trouble. I unplugged it, re attached the battery, nothing happened. Pfew. IPC, diagnostic socket, and driver door modules are probably OK. I unplugged the battery, reattached the door connector.
Unplugging the passenger's door connector isolates the climate control module, audio head unit, and companion camera if fitted. I did that and then reattached battery and BAM right away the radio came on and the climate unit started blowing air. So the BCM is good, the audio head unit is good, and the climate unit are all good, and their CAN wiring is good too.
I also tried unplugging the MS CAN-containing harness at the passenger door module, and everything stayed dead. So I think that module is ruled out for now too.
I've got 16 down to ~10, and I've ruled out most of the things that would cause me to need to take apart the dash thank goodness. Help is still welcome and desired, but I'm happy to be making some headway. Next is the mirror, then either the blind spot monitors or the seats.
Post #693380 26th May 2024 7:37pm
jimboy
It was the KVM all along!
As I was going around one by one to all the devices on the MS can network unplugging them, unplugging the canbus-containing harness from the KVM totally worked, and everything came back on, IPC even showed the milage (sent from bcm from the other end of the MS.can network). Suddenly my iid tool could scan dozens of new ecus. Feels good.
eBay has tons of replacement KVMs for cheap, and I think the IID tool can do the replacement programming, so I think I'll try that instead of giving $500 to the stealer.
Anyone know if I need to buy one with the same exact module number? Mine says AH42-19H440-AE but others on eBay might an AG suffix, would that be OK?
Post #693430 27th May 2024 1:37pm
georgekale
United States 2011 Range Rover Supercharged 5.0 SC V8 Baltic Blue
Did you fix your problem? With new KVM module. Having problems with my KVM.
Post #719181 5th Jun 2025 3:37am
jimboy
Yep, replacing the KVM fixed my problem. I ended up going with a new KVM after learning that the used ones can really only work if someone solders on a new virgin chip to the pcb.
Programming with iid took some iterating but the GAP guys were great - had to go back and forth about 10 times flashing my iid to test new special software revisions to get the KVM flash to take, but eventually we got it. Then a quick key program routine and it was good to go.
Post #719311 6th Jun 2025 2:22pm
georgekale
Thanks for the update. Cleared mine with SDD. It took a couple of hours, finally, I programed one key. It will not except the second key. Was there a water problem for your bad KVM?
Post #719332 6th Jun 2025 6:30pm
mmcfearin
United States 2010 Range Rover HSE 5.0 V8 Santorini Black
KVM issue maybe?!
So I have a wall of errors all "lost communication with" then list any system it is probably in the list. I was thinking a module failed but I tested every fuse and then unplugged all of the modules I could one at a time but no change. You said you disconnected the KVM and canbus came back, were you able to just disconnect the unit in the rear or did you have to also disconnect the module under the dash center. can this be tested by just pulling a fuse?
In an attempt to isolate the issue further I disconnected the primary fiber that goes to the rear, in the rear there was a high quality light coming through so no physical break. Unfortunately guess that rules out all the easy to get too ones.
Post #722752 12th Aug 2025 7:02pm
bd5400
United States 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Did you have a resource that listed all of the MS can bus network modules and their locations? My 2010 is doing the same thing and the medium speed can bus is down. Can't start the car or anything as it just says smart key not found and the backup key location doesn't work.
I'd like to try some troubleshooting on my own before I have it towed to a dealer, but I'm not sure what modules are on the medium speed can bus or their locations. I know the KVM is in the rear cargo area and the BCM is behind the fuse box in the passenger compartment but that's all I know.
Post #722963 17th Aug 2025 3:11am
mmcfearin
I did resolve the on screen warning "smart key not found" by pulling the fuse for the KVM behind the glove box, I think it was fuse F5 if memory serves. However this just made that message go away, still can't start. not registering the brake among other modules so when I put my foot on the brake and hit the ignition button it turns the vehicle off instead of starting.
I have been trying to find a decent map myself of the entire network. There are a few on google images. the KVM has two parts, the receiver/transmitter is under the center speaker in the dash on the 2010. A real pain unlike earlier models that just had it in the center consol. The actual KVM itself is in the boot on the driver side vertically mounted low in what I like to call the flood zone.
However the remote functions do work now, guess that's a plus. Not sure if that is a sign that my KVM is ok though.
Post #722988 17th Aug 2025 1:31pm
