![]() | Home > Technical (L405) > Dipstick - L405 - 4.4 tdv8 |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 403 ![]() ![]() ![]() |
I tried various options and came to the conclusion that:
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 199 ![]() ![]() ![]() |
I couldn't get the guitar string or strimmer cord to work on my TDV6. The oil suction pipe ( for oil changes) follows a torturous route to the back of the engine and no matter how much cord or string I stuffed into it, I couldn't get a reliable level indication. The 'Oil level not available' message has appeared a couple of times but has gone away when the engine is stopped and restarted. My son's MY 2020 Evoque has a dipstick and I wonder if they have gone back to a sensible means of checking the oil. |
Two Tone Member Since: 17 Aug 2025 Location: GL56 0PN Posts: 6 ![]() ![]() ![]() |
How about replacing the sump plug with a ‘T’ shaped pipe junction screwed into the sump drain hole, with a bung in the second part on the ‘T’ and a relatively straight hose extending from the third part of the ‘T’ to somewhere along side where the suction oil drain pipe is, using a proper dipstick inside that hose to show exactly what the oil level is? |
Hmm....
I just added a comment to this video:
No, I’m sure you wouldn’t need to cap it off as in effect the bottom of the Dipstick tube is below the level of the oil. In fact it is at the very bottom of it. |
On the TDV6, the pipe for sucking out the oil with a pump enters the sump right next to the drain plug. The dipstick tube might have to be temporarily blanked to stop the pump from taking the path of least resistance and sucking air through the dipstick tube when doing an oil change.
