Home > Maintenance & Mods (L405) > Tailgate Stay - Caught it early
sullivj
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
I noticed some surface rust on my tailgate stay, so rubbed it off and treated it with some Kurust.
I'll paint it once that's dried.
May be worth lifting the carpet flap and checking yours.
Post #723090 19th Aug 2025 4:00pm
firstrr
England 2019 Range Rover Autobiography SDV6 Santorini Black
Very good advice.
But also to check and grease the ball and socket which do wear out and pop off, (and this on my 2019 AB model) That’s how I found out when the tailgate wouldn’t shut. New actuator and hinge to solve the problem. Beware all!
Post #723103 19th Aug 2025 7:55pm
sullivj
Is it possible to separate the ball and socket in situ..?
Post #723106 19th Aug 2025 8:06pm
firstrr
Well mine had disintegrated - including the spring steel retainer that is attached to the end of the actuator which you can see if you zoom into the picture of the new one below. When I fitted the new one it was a case of grease then press the socket onto the ball (hinge).
I guess it should spring back off if you prise it but if it is corroded then probably disaster!
I think I have seen replacement spring steel retainers shown on here by a member who found some on flea bay. Maybe someone will shout up.
Get it wd40 , clean and greased first then it has a chance to come apart easier.
Post #723108 19th Aug 2025 8:45pm
Gremlin500
Yes, this is a very common thing to corrode on the L405, there is also down to the left, at least on my MY2017, a completely unpainted bolt which gets very rusty. I replaced with a new one wich I painted before replacement. I recommend checking a couple of times a year and applying ACF-50 or Lanoguard grease or similar. V6 Vogue - “Less is More” - less to go wrong!
Post #723111 19th Aug 2025 10:59pm
bigdave
Site Sponsor
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
Hi Gremlin500,
Mine is looking v rusty - id like to replace before it fails.
Do you really the part number for it?
Thanks.
Dave
Thumbs Up All things transport - big or small, UK or planetwide.
E-mail info@md-couriers.co.uk
Post #723119 20th Aug 2025 9:28am
Gremlin500
If it’s M8x30, then LR037087, plus a can of touch-up. V6 Vogue - “Less is More” - less to go wrong!
Post #723126 20th Aug 2025 12:31pm
bigdave
Site Sponsor
Thank you good Sir. All things transport - big or small, UK or planetwide.
Post #723127 20th Aug 2025 12:33pm
bigdave
Site Sponsor
Do you know the part number for this item please? All things transport - big or small, UK or planetwide.
Post #723128 20th Aug 2025 12:44pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
I think it is LR034445
https://britcar.com/product.php/189167/549...___2013_0n _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #723132 20th Aug 2025 12:59pm
bigdave
Site Sponsor
Thumbs Up Thumbs Up Thumbs Up Bow down Bow down All things transport - big or small, UK or planetwide.
Post #723136 20th Aug 2025 2:59pm
firstrr
Yes confirmed as part number LR034445 Actuator
I purchased mine from John Craddock Ltd, Cannock, Staffordshire. ( best price at that time - Jan 2025)
Post #723144 20th Aug 2025 8:04pm
