| Help in identifying connector type | |
I recently replaced the connectors on the fuel sender(s) and active pump in the tank with crimps as per a service bulletin.
When I removed the carpet, I discovered that some of the insulation has been rubbed off one of the wires entering the primary connector into the tank i.e. the one outside of the fuel tank with all the wires.
 | | Click image to enlarge |
I'd like to remove it in order to access and fix the damaged part of the wire.
What type of connector is this (Packard, Delphi ... etc)? I want to find out how to de-pin and reinstall it. 2011 L322 Autobiography 4.4 TDV8
