![]() | Home > Maintenance & Mods (L405) > l405 lower control arm torque settings |
nike_bytom Member Since: 29 Mar 2025 Location: Thrapston Posts: 27 ![]() ![]() ![]() |
Attached:
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1878 ![]() ![]() ![]() |
At normal ride height, remember. V6 Vogue - “Less is More” - less to go wrong! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
remember doing the equivalent arms on my 322, to obtain "normal ride height" I think I had to do the bottom ball joint nut first then put a trolley jack under the hub and jack it up to road height measured in relation to the arch from the centre of the hub. its pretty much the only way to do it if you don't have a ramp as getting enough room to swing a long bar to 100Nm and 360deg under the car in normal height is tricky..... There is nothing that can't be fixed with a hammer😜😜
