Home > Technical (L322) > FBH: manual buttons on main screen not working
robkuijpers
Netherlands
Hi Forum
Using the IIDTool I enabled the Timed Climate of my 2012 RR TDV8. With this setting in the CCF the Timed Climate option is now visible/selectable. I can set Timer 1 and 2, and experienced that the fan starts at the time set. Haven't experienced timed heater though.
But there are also two buttons blacked-out, Manual heat and Manual vent, these are not responding (that's why they have probably black texts). What is the function of these two buttons and how can I enable these? Is this why the Timed Heater doesn't work?
Best regards
Rob 2012 RR Vogue 4.4 TDV8 Sumatra Black
2004 Defender 110 Td5 Epsom Green, 'Alive' Chip tuned and a Warn 8274 Winch
1978 Citroen Mehari Orange Kirghise
2001 Defender 90 Td5 Softop (gone)
1992 RR Classic 300TDi 'Soft dash' Green (gone)
1989 RR Classic V8 Caspian Blue (gone)
Post #631018 8th May 2022 10:18pm
mjdronfield
Vent will not use the FBH at all…. The fans will come on to blow any hot air out the car, so when you open the door, it’s not really hot inside.
Heat uses the FBH to heat up a cold interior.
Not sure why they are greyed out.
Have you tried the buttons with the engine off?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #631019 8th May 2022 10:32pm
rjff
Rob
As on mine (11MY), leave the "ignition" off and turn on the audio with the centre push button to the left of the centre screen.
Select
home,
timed climate
and you should see the buttons come live.
HTH. Cheers
Richard
Gap IIDBT
Post #631048 9th May 2022 8:52am
robkuijpers
Netherlands
Thanks Richard,
In that scenario, the text of the 2 buttons 'manual heat' and manual vent' becomes white. But when pushing each briefly an orange border appears (indicate you touched the button), but in MHO not much happens. The orange led of the A/C (auto) switch below briefly lit once up as well as the fan briefly is activated but that it. The manual also doen't explain a lot about these 'manual' functions.
This function keeps me puzzled.
Post #632975 26th May 2022 6:33pm
FatBoyii
Did you ever fix this. Mine does the same
Post #723250 22nd Aug 2025 10:17am
