Home > Technical (L322) > 5.0sc cranking a long time before starting (occasionally)
Super7
Hi all, I've noticed my l322 5.0sc is occasionally cranking a long time before starting, I guess it's doing this once every 20-25 times I start it.
It does start but normally it starts quickly just after a few turns. Is this a sign of an impending failure of ignition component or fuel issue? It's had new plugs, Oil and filter and injector cleaner which use occasionally as it runs a Prins lpg system, it's only done it 5 or 6 times I guess but concerned it could be a sign of a developing problem?
Engine has never missed a beat in the 50,000 or so that I've had it.
Has anyone had a similar experience/problem? Current 5.0 S/C Autobiography LPG
110 HCPU V8
Previous:
P38 first ref LR1
101 Forward Control
90 CSW V8
110 CSW V8
Post #723273 22nd Aug 2025 4:56pm
cass
Have the LPG injectors been serviced recently?
It’s quite a common issue that as the LPG system is still pressurised when the engine stops, if you’ve got an injector starting to leak then it “floods” the manifold causing the problem you’re seeing.
Post #723285 22nd Aug 2025 10:32pm
dingg1
What cass said will most likely be the issue, once the temperature drops and no sun on the bonnet, it'll probably dissappear....
Post #723287 22nd Aug 2025 11:39pm
dhallworth
I had a similar issue on my 4.2. It wasn't an LPG injector leaking though, it was the LPG reducer. The diaphragm inside the reducer had failed so it was filling the vacuum line and inlet manifold with LPG when the car was switched off so it had to crank for a long time before starting.
If I ran it solely on petrol the issue didn't happen so might be worth leaving yours off LPG for a while to see if the issue stops.
Post #723288 23rd Aug 2025 12:02am
Super7
Thanks for the advice everyone, I will have a look through the lpg system and get the injectors serviced, I know the vapour and liquid filters were changed a while back but I'm pretty sure the injectors were not serviced.
I will run it on petrol for a while as suggested and see and in the meantime get them serviced.
Thanks, very much appreciated. Current 5.0 S/C Autobiography LPG
110 HCPU V8
Previous:
P38 first ref LR1
101 Forward Control
90 CSW V8
110 CSW V8
Post #723289 23rd Aug 2025 12:23am
Super7
A
Morning everyone,
Ok so I've tried the lpg injector cleaner and the system has faulted! it won't change onto lpg, so a couple of questions.
Does anyone know if the software is available for the prins VS1 direct injection system? Lpg shop list them but out of stock.
Now I'm running on petrol only it has sort of eliminated the lpg as the cause of the lengthy cranking, it's still happening on petrol and tends to be the first cranking of the day no matter if it's first thing or late afternoon, ir if the car has been stood for a few hours, does this point to a drop in fuel pressure at the injectors after a period of time? I have just purchased a GAP 4 so I could check the fuel pressure before starting etc but could someone tell me what it should be please?
Or if anyone has any other ideas of the cause I would be grateful to hear them.
Many thanks Current 5.0 S/C Autobiography LPG
110 HCPU V8
Previous:
P38 first ref LR1
101 Forward Control
90 CSW V8
110 CSW V8
Post #723693 31st Aug 2025 10:14am
