![]() | Home > Technical (L405) > 4.4 SDV8 oil leak. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1827 ![]() ![]() ![]() |
Get the undershields off and give it a good jetwash clean underneath (or preferably get someone to do it for you on a lift) then take it for a good long motorway blast with the shields off on a warm dry day, refit shields & report back. V6 Vogue - “Less is More” - less to go wrong! |
MGSED37 Member Since: 09 Aug 2025 Location: West Midlands Posts: 9 ![]() ![]() ![]() |
Going to have to dosomething as it really does stink in the cabin. As well as smoke when standing still. Could this still be residual oil leakage? Thank you gremlin will definitely look at this. |
Anything else leak wise to look out for? Is this a common thing? |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1415 ![]() ![]() |
It takes a good clean as the oil gets in all areas of engine bay which can be difficult to remove. Then take it on a motorway for an hour to help burn off residual oil, a good hot Active Regen will also help.
Many thanks for your reply.
