Home > Technical (L405) > SDV8 EGR valves
SDV8 EGR valves
Hi all,
I’ve been using the old bus quite a bit recently and I’ve noticed that the eyes have started to get a bit noisier when you shut the car down? Used to be a noticeable noise now it sounds slightly clunky when they are cycling. Had anyone else found this.
Has anyone swapped the EGR valves on an SdV8? Not impartial to having a go if it’s not too difficult. Will have to have a read of the WM….. There is nothing that can't be fixed with a hammer😜😜
Post #723309 23rd Aug 2025 2:56pm
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
fairly straight forward, i removed the EGR and cooler for my issue (long story) there is some hard to reach / not much room bolts on the back of the egr that bolt below the crossover pipe i used a short ratchet. ill try send you what i followed, steps 17 - 20 show the bolts mention above
EDIT cant send you what i followed but its in the WIKI service manual - engine emission control its for the TDV8 but is the same for the SDV8
 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #723313 23rd Aug 2025 4:16pm
Thumbs Up just looking at parts. A pierburg one seems to be the most general available, at a few hundred less than a LR one. Chances on that being the same piece of kit as the Gen one……… Whistle There is nothing that can't be fixed with a hammer😜😜
Post #723330 23rd Aug 2025 9:54pm
Andyyav
A very good chance!
Some info off my genuine one for comparison if / when you look into it
1992 90 Exported
2016 L405 4.4 AB
Post #723349 24th Aug 2025 9:56am
JayGee
“ I’ve noticed that the eyes have started to get a bit noisier when you shut the car down?” - are you sure it’s the EGR valve? The throttle plate goes through a few open and close cycles on shutdown to free off any soot buildup and this can be quite noisey. 2012 TDV8 Vogue (L322)
Post #723401 25th Aug 2025 12:48pm
not had a chance to look into it over the weekend. But it's on the job list for the coming week. get the bonnet up and have a listen and a poke around to see what is making what noise!
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #723426 25th Aug 2025 5:32pm
