Home > Technical (L322) > 2011 fuel gauge
Page 4 of 4 <1234
JayGee
Still running mine with a variable resistor to fool the ECU and not exceeding 500miles between fills. I really should get round to fixing it but it looks like it could be a nightmare. 2012 TDV8 Vogue (L322)
Post #723048 18th Aug 2025 6:26pm
rjff
Twin RR
Pleased my post was of value and many thanks for your kind acknowledgment.
JayGee
Not as bad as you think, particularly if you have the fuel level low. Cheers
Richard
Gap IIDBT
Post #723050 18th Aug 2025 6:40pm
Rackers
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
It definitely isn't too bad, just messy and make sure the fuel level is low or it'll be really messy.
Post #723089 19th Aug 2025 2:28pm
JayGee
Thanks for the encouragement. I keep my fingers crossed it’s the first connector that may reestablish operation with some unplugging and plugging back in. Does it help parking on a slope facing up or down? 2012 TDV8 Vogue (L322)
Post #723095 19th Aug 2025 5:12pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi JayGee,
I found flat ground was ok, I'm not sure if elevation one way or another would help.
I made the mistake of replacing a suspicious looking connector, assuming I'd fixed everything, I put most stuff back together and put fuel in to test. Only to find I'd got that wrong, I was then swimming in diesel! My suggestion,.......take it all out of the tank and replace all connections.
Hope that helps a bit! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #723098 19th Aug 2025 5:59pm
FJ12Jagmen
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Did mine recently and learnt a couple of things
1) lie in the boot, you can't do it standing in the door.
2) when testing fuel gauge after reassemble connect all the pipes otherwise diesel goes everywhere Embarassed
3) make sure you cable tie all pipes as per original. They can interfere with the level sensor and give the same symptoms as faulty connections.
4) much easier the second time. 2007 3.6 TDV8
1979 Mini Special
1988 Yamaha FJ1200
!952 BSA Gold Flash
Post #723350 24th Aug 2025 10:01am
Page 4 of 4 <1234
