Home > Maintenance & Mods (L322) > Coolant Change / flush
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
Been through every topic on the board, I have been losing some coolant over the past few months, but feel I should flush it and change / cleaner header etc and generally give it a bit of an inspection. Cant find anything relating to a 'How To' on this, I know its not the most technically demanding job but if anyone has anything I may find useful, it would be appreciated
I have also read about these testing kits you can buy to check the condition of the coolant (i.e. its not been mixing with anything nasty from the cylinder head) and wondering where I may be able to get one (piece of mind), anyone??
Out of interest, would no a/c (compressor I think) affect coolant level?
Thanks in advance Thumbs Up
Post #72238 13th Jul 2011 3:24pm
pretlove
i had this issue with my 4.4 and it appears to be a slow leak from the radiator hope this helps....and with regards to the testing kit try any good car parts shop i.e eurocarparts Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #72246 13th Jul 2011 4:51pm
Hi Phil
The best thing you could get is a copy of Rave. You can download it from matts website. Www.myrangerover.com
The coolant change is easy to do but make sure your heater is set to full heat before you start. You can do a full change where you remove the plug from the block and change all 14L of it of just remove the botton hose of the rad and let it drain. What engine have you got? I'm guessing a 4.4?
Post #72247 13th Jul 2011 4:53pm
pretlove
according to his pic he has a td6 "RANGEISM WILL NOT BE TOLERATED"
Post #72248 13th Jul 2011 4:54pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
I was loosing collant on my TD6, untill I added more coolant / anti-freeze
Post #72250 13th Jul 2011 5:01pm
liverpoolphil
cheers for the tips
....would never of known that without asking Wink
Yeh, its a TD6, probably being a little over cautious but wouldnt mind just draining and checking it out anyway, 14L thats a decent amount of coolant. Given that I've probably only put a litre in during the past 6 months, I have to assume its only a small leak, may well be the slow leak from the rad mentioned by prelove
Have a copy of rave, will have a read over a glass or two of vino tonight
Thanks again Thumbs Up
Post #72260 13th Jul 2011 7:07pm
Phil
Most/all my knowledge is on the petrol so yours might not be 14L. The petrols are prone to rad leaks in the lower left and often go UN-noticed as the fan disperses the fluid before a puddle forms under the car. 1L over 6 months isn't a lot but worth finding where its going. I have a water leak and am putting in about 1L every 2 weeks. If it wasn't landing on the floor I would be worried.
Post #72317 13th Jul 2011 11:28pm
liverpoolphil
thanks for your help and advice
Can anyone clarify if in-operational a/c can have any affect on the coolant level?
Post #72336 14th Jul 2011 11:36am
