Home > Technical (L322) > RHS rear tail/fog lamp not work
mugball
Ireland 2007 Range Rover Vogue TDV8 Epsom Green
Just got a 2007 TDV8 with a "Check Rear Fog light" message on dash, and rhs rear tail/fog not lit. Indicator, upper tail light, brake light working fine.
As only one side assumed simple bulb replacement, but have checked bulb and it is definitely fine.
Connectors look clean, wiring to lamp unit looks ok. All completely standard, ie no LED conversion or any other lighting upgrades.
Any ideas what else could cause this? Presumably these aren't individually earthed?
Post #723373 24th Aug 2025 6:10pm
mugball
I know also have a check sidelight message on dash which appears to be front LHS, haven't checked bulb yet but suspect it is fine.
Post #723476 26th Aug 2025 6:00pm
mugball
After a bit more searching I am beginning to think this might be an LCM issue, does that make sense to anybody?
Post #723480 26th Aug 2025 6:34pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
I had an issue with the fog lamp
On one side, I bought a Chinese replacement and nothing. At that point I started thinking its the wiring so I took out the taillamp and cleaned the wires, checked the prongs.
That worked, but realized I had the wrong bulb! So ended up ordering a very expensive LR fog light bulb and that solved all the problems 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #723535 27th Aug 2025 3:12pm
mugball
Unfortunately in my case it is definitely not bulb. to triple check I swapped them from side to side and still have same problem on RHS whilst LHS works fine.
Post #723536 27th Aug 2025 3:23pm
JCW
I have a vague recollection the front / rear lights are fused on diagonal corners - if the front side light is also out on the diagonal side, may be worth checking relevant fuses if not done so already.
I may be completely mis-recalling this however! Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #723537 27th Aug 2025 3:41pm
mugball
Thanks, didn't know that, but fuses are fine, checked them, and other functions covered by same fuse fine. Plus front LHS sidelight fault is intermittent.
Post #723553 27th Aug 2025 10:25pm
