![]() | Home > General > Alarm Issue |
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
is there a lorry or other vehicle going past it (if it's parked on the road) that is activating the tilt switch or glass tamper ?
Ninja Member Since: 14 Jul 2011 Location: Midlands Posts: 6 ![]() ![]() ![]() |
No it is not parked near a road as we live on a Farm. No animals or children go near it. It is almost as if it is pre set to go off at that time!!!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35821 ![]() ![]() |
member supershuttle had a similar problem, the suggestion was to disable the bonnet switch and this seems to have solved the problem.. |
Yes I read that but why would it go off at the same time each day?? |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
Check to see if auxiliary heating or ventilation is programmed to come on at that time? |
its a process of elimination ninja, got to start somewhere.. |
ric355 I will have a look later but I cannot remeber setting it and I doubt I could work out how to do it !!! |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
Pre-heat and vent has been known to create an issues due to the air movement inside. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3945 ![]() ![]() ![]() |
Disconnect the bonnet switch first it's quick and easy, if that cures things you have found your problem and can either replace or service/adjust as I did, if not look elsewhere.
Thank Supershuttle.
Problem Solved |
result... |
good news !
I WANT YOU TO LOVE ME ? |
