![]() | Home > Technical (L322) > 2012 tdv8 bonnet release cable loose not snapped at handle |
diabloam Member Since: 22 Oct 2024 Location: Isle of Lewis Posts: 33 ![]() ![]() ![]() |
to get bonnet open
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 712 ![]() ![]() ![]() |
You can't get to the bonnet catches via the grille aperture. LR have learnt from previous security mistakes on other models and fixed a metal panel below the cable run area.
Thanks, do you need to get hold of the end where it joins or can you just pull the whole thing to release? thanks |
Reached up as suggested and got it, thanks for tip. When i had fitted new handle and cabin part of cable, where it joins, I hadnt obviously clicked the wee connector box back together properley and it had opened and allowed cable to detach, sorted, thanks |
