Home > Maintenance & Mods (L322) > Transmission fault P0721-62 and P215-62 - transfer box?
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Had a gearbox fault for the first time on my 4.4TDV8.
Last night I got onto the motorway and after a couple of miles it felt like the car shifted down a gear (constant speed, 70mph), then fault message came up and the car limped at 60mph.
Got off Mway, stopped engine (with a loud clunk when it stopped), restarted. Drove another 20 miles with no issues.
This morning, 2 mile drive to work, and it did something similar (but worse) - after stopping there was virtually no drive forward or reverse, but a metallic whirring sound. Repeated restarts didnt do anything.
I've read the codes:
P0721-62 (output shaft speed sensor - circuit range / performance - signal compare failure)
P0215-62 (vehicle speed/output shaft speed correlation - signal compare failure)
After reading the codes I had a play - after putting it into low range then back into high everything seems to be working normally.
Anyone recognise the fault?
Post #722792 13th Aug 2025 1:47pm
RRPhil
I assume you mean P0721 for the first code (typo?). The transmission output speed sensor is connected to the electronic module of the Mechatronic unit. I wonder if it might be worth disconnecting the 16-pin plug at the back of the transmission, checking the pins all look okay (not bent, corrosion-free) and then reconnect it again? Note that only 7 of the 16 pins are used with the 8HP70. Clearly this is a bit of a long shot.
There’s definitely no codes from the Anti-lock Braking System?
Sometimes, output speed sensor codes are flagged because there’s a mechanical issue causing the output speed to not tally with what the TCM was expecting, and it incorrectly interprets this as a speed sensor fault. For example, when the spline on the transmission output shaft starts to fail due to fretting corrosion caused by lack of lubrication. Hopefully this is not the problem in your case.
Phil
Post #722804 13th Aug 2025 7:04pm
NDT
thanks Phil
The only code from the ABS was UO402-68 - invalid date received from TCM - Event Information.
I drove the car 2 miles home tonight and the problem didn't come back.
Post #722807 13th Aug 2025 7:38pm
NDT
Having done a couple of flawless journeys, she’s failed again and I’m awaiting recovery on the hard shoulder.
How hard is a transmission swap?!
Post #722870 14th Aug 2025 7:40pm
NDT
yes - you're right. 721. I will check the plug - would this cause a loss of drive?
Phil
I thought the fretting issue was on the earlier cars - mine's a 2011.
When they have this problem, is it intermittent or does it just go (what I'd expect).
Having spent 12 hours being rescued, the car now drives normally, which is frustrating.
When the problem comes up, there's virtually no drive and a whirring / rubbing noise.
Almost like the transfer box has got into neutral.
Post #722950 16th Aug 2025 4:54pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Have you checked the front driveshafts? On mine the front right one sliped out and caused this metalic whirring sound and no drive. The first transmission guy changed the mechatronic, Censored no change, the second transmission guy found the driveshaft sliping out every now and then. Meanwhile the transferbox was f**ked off Big Cry so had to change that one too. About the same faultcodes as I recall.
Post #722968 17th Aug 2025 7:29am
NDT
Will check. First need to get it to do the fault again.
I changed a CV joint last month. Feels like that’s the obvious shaft to look at - although I was sure it was in properly.
Post #722969 17th Aug 2025 7:34am
NDT
Looks like it was the driveshaft. It’s been 4 weeks and 1500 miles since I reinstalled the driveshaft.
I didn’t fit a new snap ring on the diff end. Looks like it’s been slipping out - when jacked up yesterday I could pull it out of engagement easily.
Post #723039 18th Aug 2025 12:58pm
NDT
Thanks for your suggestion - this is what it was!
Post #723522 27th Aug 2025 11:21am
