![]() | Home > LPG > Is compressed home natural gas a viable alternative to LPG |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
Anything combustible will work to a certain extent in an ICE - the trick is to get it into the right place under the right condition to explode.
montyjohn Member Since: 07 Feb 2023 Location: London Posts: 19 ![]() ![]() |
Just did a little googling, apparently Natural Gas (mainly methane) contains 2.5x less energy per volume (I assume at the same pressure) when compared to Propane. Apparently LPG is a mix of Propane, Butane and isobutane which I believe are all similar. So on that basis I would say using natural gas, even if you could compress it at home is a non starter. 2000 P38 4.0 HSE auto - RHD - just needs a little love. |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 200 ![]() ![]() ![]() |
I don’t think compressed natural gas need be a viable alternative. I understand that, whilst LPG is being phased out in vehicle fuel stations due to low demand, LPG as a fuel source in the UK is not.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1517 ![]() ![]() |
Many years ago when I had my LPG rangies on the go, I remember there being a long discussion on one of the LR forums whether it would be feasible to have your own LPG tank to fuel vehicles, and I think the consensus was no, primarily because of not be being able to get a large storage tank from the suppliers, and the cost of the fuel being not that much of a saving over the pump price.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1401 ![]() ![]() |
Cng is used on some buses.
SpannersNK Member Since: 25 Aug 2025 Location: Kent Posts: 4 ![]() ![]() |
I looked into this when we had a home bulk tank installed. (Flogas) Technically yes it's easy as they just install a bottom feed or a second top feed with a tube so you can get liquid rather than the gas you take for home use.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
A local farmer uses a bulk tank to refill his small quad type jeep. When I ran a food factory we had lpg trucks got yard work again filled from a bulk tank. Think they had a hand pump for transfer but it was several years ago! 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
