|  | Home > Technical (L322) > How To: Replace Air Conditioning Compressor on 4.4 TDV8 |
| Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69      | In order to replace my Radiator, I just had my AC de-gassed. I am going to replace the AC compressor as well as I have this problem that ac blows cold intermittently.
|  26th Apr 2024 6:04am |
| Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262      | If not used regularly, AC systems do leak refrigerant - which is why in the UK at least people are constantly selling cars that 'just need the AC regassed' because they've never turned it on.
|  26th Apr 2024 7:44am |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494    | The 4.4 TDV8 has a recognised fault with the air con compressor control valve.
|  26th Apr 2024 8:40am |
| Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69      | Thank you guys for your feedback. Im aware of the issue of ac valve getting stuck. Thats why Im going to replace it, hence I degassed the system.
|  26th Apr 2024 9:32am |
 Indeed it does, but the post I replied to specifically asked whether having a smaller weight of charge in the system was indicative of a leak - which can indeed be 'about whether A/C has been used or not'. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! | ||
|  29th Apr 2024 8:14am |
| Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69      | Hello everyone,
|  3rd May 2024 5:15pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | That is showing the sump. The 4 bolts across the top screw through the sump into the oil pump which can be accessed from above but the 2 holding the pipe will be much lower so will have to be accessed from below. | ||
|  3rd May 2024 8:32pm |
| Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69      | Thank you Greames, i found them and undid them. They secure second aircon pipe.
|  4th May 2024 12:15pm |
| Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69      | To put the new compressor in, I removed the pully right to the tensioner next to the ac comp. There is a lot of gung in that area right above the ac comp and steering pump. Is there a leak here? What are the common leaks around this area?
|  4th May 2024 8:34pm |
| AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 709      | Hi,
|  28th Aug 2025 11:24am |
| RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 147    | My AC is on the blink too. It's occasionally sort of there then not. I don't have the time or patience to tackle this even though I've got the space and most of the tools, so it looks like it's going to be another £1k plus bill. That will be number 3 in a year!
|  31st Aug 2025 5:50pm |
| AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 709      | Mine was intermittant, it got progresively less so, sometimes the AC would come on just when you got to wherever it was you were going, sometimes straight away and sometimes not at all for a few days. All that work just to change the valve and find out it wasn't that would have been too much to bear.
|  1st Sep 2025 11:17am |
| Posting Rules
