![]() | Home > General > Vogue SE Cooled seats |
| kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106
there should be two twistable knobs on the dash with a seat picture on it and you turn in left for cooling (lights go blue) or right for heating(lights go red) |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
The knobs also have a pic of a seat bottom and back that illuminate and you can direct the cool air to either your back your rear end or both! Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
| Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191
My SC VSE dont have cooled seats |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Nor mine , but my windows open |
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936
Wasn't it 2007 on that got perforated seats 'n' cooled tush? |
| Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313
That's what I thought. Basically, if you have a button for heated seats, you don't have cooled. If you have a dial for heated seats then it twists the other way to cool instead of heat. |
| Kads Member Since: 08 Jun 2011 Location: Thurrock Posts: 30
Grrr |
So you stick your ar5e out the window to cool it like? Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
| johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519
Standard equipment from MY07 on Vogue SE and above. As others have said, the dial is the giveaway. |
I meant I put the window down if I want to let air in the car since I don't have cooled seats as a joke So why the |
Erm, no offence intended! It was your ar5e hanging out the window that was Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
No offence taken Al just curious , too old to get offended |
Cool! Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
How easy it is to offend via email & forum posts........ |
| All times are GMT |
