![]() | Home > Maintenance & Mods (L322) > Subframe bush replacement issue |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 205 ![]() ![]() ![]() |
So I refreshed the subframe bushes as part of my complete bush replacement programme on the car and have noticed an issue since fitment. In short, the front pair are not seating correctly and it is my best guess that the replacement parts are not quite the same height as those that were removed. The pictures below show what I mean.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
Did you rivet the new ones in? |
No, but that’s one easy option. I just need to first compare the dimensions of the replacement bushes vs the old OE bushes to see whether there is indeed a difference that might cause this. The issue I’m trying to avert is putting the subframe out of its intended alignment and relative level in the front-to-back horizontal plane. In other words, is the subframe in the correct horizontal alignment and the bush is actually out of spec. Or, is the bush correct and I do indeed need to press the bush back in and rivet once done to keep it there.
Yes, see those posts and elected to go with KHC000050 and KHC000060 equivalents to avert the BMW bush gripes.
So I went out with the vernier this evening and had a proper look. I drew a diagram to explain and to illustrate the issue. Bottom line is that the front of my subframe is sitting about 12mm higher than I think it should, so possibly affecting things like propshaft alignment out of intended spec.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 988 ![]() ![]() ![]() |
These subframe bushes from PSB have had good reviews £175 for the set
Ha, these were the exact ones I was looking at. Powerflex equivalents are over twice the price!
