Home > Technical (L405) > Rear suspension low with trailer
Flash
Sweden 2015 Range Rover Autobiography SDV8 Kaikoura Stone
I regularly pull a a large heavy trailer and I have noticed the rear is constantly 3cm lower than without load. Normally the center of the tow ball is 40cm above ground but with the trailer on it is constantly at 37 which is a bit low and on uneven ground it can be to close to the ground.
I have no error messages with the trailer hooked up and I can still raise the suspension but when going back to normal level it is again 3cm low.
Anyone experienced anything similar.
Post #723419 25th Aug 2025 4:32pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Has it been coded to stop it dropping?
Or do you mean on the move it’s low?
Post #723462 26th Aug 2025 1:01pm
Flash
With the trailer hooked up the rear is constantly 3cm low both on the move and standing still. My Disco 4 always levelled off at the same height regardless of load or trailer.
Can the suspension be coded to have a different height when loaded vs unloaded?
Post #723465 26th Aug 2025 1:19pm
zenman63
Well it should level so get the codes looked at, hight sensor probably.
Post #723469 26th Aug 2025 2:35pm
Flash
How would an issue with the height sensors only materialise when the trailer is hooked on?
Post #723470 26th Aug 2025 2:38pm
mjdronfield
What does your 4x4 info screen show? Is there a difference between loaded and unloaded? That shows the height sensors…..
If the height sensors show the same height, maybe it’s the tyres squashing due to extra load, but that does seem a lot to just be tyres…. Only a thought….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #723472 26th Aug 2025 2:54pm
Flash
I recalibrated the suspension with my GAP today and it turns out it was more than 10mm to high in the front more than 10 mm low on the right rear wheel. Will be interesting to see what happens next time I hook up the trailer.
Post #723815 2nd Sep 2025 2:30pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
I regularly tow a cattle trailer with stock so 3 ton + behind the L322 and the suspension height never changes much, once hooked on the suspension levels itself and off we go. I did calibrate the suspension after I bought an IID3 tool and that showed differing heights on every corner, (not that I ever noticed) reset the heights and since then it has all been fine.
Post #723836 2nd Sep 2025 9:54pm
