![]() | Home > Technical (L405) > Wet headliner above A Pillar |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
If it's getting wet above the level of the windscreen I'd think it was the pano roof not sealed properly...
| linus Member Since: 04 Jun 2025 Location: Herts Posts: 25
That’s interesting, so it’s a liquid. Is it clear?
IIRC it starts white so you can see where it is, then it dries clear... |
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1441
See this
That's a useful document, thank you.
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134
Don't just wait for there headlining to get wet. Remove as much internal trim as you can & get a torch up there, then start pouring water.
I’ve seen people using compressed air to find leaks in windscreens. They just run water over the joins from the outside and use compressed air from the inside to see if it disrupts the flow of water. I think I have to strip of some trim.
