Home > Technical (L322) > transmission gearbox faults
Stev
Austria 2009 Range Rover HSE TDV8 Alaska White
Hello fellow Range Rover sufferers 😉
On my drive to work today, I encountered five transmission faults followed by reduced engine performance. I then read the codes using the GAP tool and got these three error messages.
Can anyone tell me what first steps I should take to identify the issue?
Best regards,
Stev
Post #723918 4th Sep 2025 7:20am
First thing to check is battery voltage should be around 12.6 volts 30 min after switch off... Thumbs Up Pete
-Click here for Thread-
Post #723921 4th Sep 2025 10:09am
Stev
I just had it towed.
The starter works and the engine turns over, but it simply won’t start.
I’ve now connected it to the battery charger and will try starting it again this evening.
I'm beginning to suspect that the engine has caused the transmission error
Post #723935 4th Sep 2025 12:35pm
