Home > General > 4.4 or 3 litre
Flash
Sweden 2015 Range Rover Autobiography SDV8 Kaikoura Stone
Used to drive a Disco 4 with SDV6, worked perfectly in the five years and 60 000 miles I drove it. I invested in an Alive tune giving it 300 HP and 700Nm, huge improvement but it still needed quite high revs before it started moving.
Earlier this year I moved to an L405 with the SDV8 and I would not want a different engine in it. The torque, brakes and ACE makes it a very nice effortless drive, none of which you get in the 3.0. Only thing I will change is reprogramming the throttle response to get rid of the lag when accelerating, the same goes for the SDV6, it also has too much lag.
With all that said, if you go for an SDV8 it has to be in really good shape considering the extra tech it has, so maintenance is potentially quite a bit more expensive on the SDV8 than the 3.0.
Post #723949 4th Sep 2025 3:39pm
Vogue
No timing belts to change on the V8 Diesel either 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #723960 4th Sep 2025 7:37pm
Adaptive
4.4 any day
Post #724015 5th Sep 2025 3:18pm
Vogue
Wouldn’t entertain the 3.0 V6 - I’ve seen the issues and catastrophic costs first hand - on more than one occasion - direct family and several friends. LR even issued their own TSB acknowledging there is a fundamental issue with this engine. No more evidence needed ! 🙈 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #724037 5th Sep 2025 10:23pm
warewolfas
Latvia 2010 Range Rover HSE 5.0 V8 Santorini Black
4.4 all day long if you are choosing a diesel
Post #724061 6th Sep 2025 1:12pm
Had tdv6 L405 for four years a have now a sdv6 for a year so far and I've had now problems....lovely engines with excellent mpg... ... - .- -.
Post #724067 6th Sep 2025 2:26pm
