Hi - I have just finished todays job, which was replacement of rear hub bushes, when I went to start the car to test drive, it appeared the battery was flat (screen worked, lights came on, but when I pressed the ignition button it didnt fire up). I assume that the battery was drained as I left the door open for a long time so I attached my battery charger (whilst the battery was still connected to the car) and when I connected it to the mains the fuse on the battery charger popped and the negative lead of the battery charger melted! Can anyone shed any light on why this happened - is it because I should have diconnected the battery from the car first? It is a 2012 4.4 tdv8.
Also, am i likely to have damaged anything on the car?
Thanks Tom
