![]() | Home > Maintenance & Mods (L405) > 5L cooling tubes |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1875 ![]() ![]() |
Replace them for aluminium parts where possible
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 256 ![]() ![]() ![]() |
Is it worth doing the water pump and connecting tube and belts.
Inigo Member Since: 15 Jan 2014 Location: Kent Posts: 60 ![]() ![]() ![]() |
I'm slowly gathering parts for this. I have the genuine Y-piece and top pipe from the V8 Defender. Are the others available in aluminium from LR or are there only versions available from thrid parties? Suggestions from other forums are that the unofficial parts aren't particularly great fitting. |
Interesting the defender went back to aluminium? |
Well it’s very common apparently, and Land Rover have gone back to Aluminium.
Update on this as it’s now showing its ugly head.
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 95 ![]() ![]() |
I bought an aftermarket kit with lots of stuff from the US, and did the replacement based on a crappy pair of YouTube videos. Service manual was not very helpful.
If you need to drop the rear subframe to replace those pipes, also consider doing the ARC + AC pipes at the same time... |
Hi ,yes I will drop the subframe and the tank and change the rear pipes.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
pretty sure that Craig did a thread on the rear AC line fix somewhere.... There is nothing that can't be fixed with a hammer😜😜
