Home > Maintenance & Mods (L322) > 5.0 SC Timing Chains
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, quick question for those in the know and been through the timing chains issue on the 5.0 SC. I've been through the various threads but I've not found a black & white answer,
I'm looking at trading in my 4.4 TDV8 Westie for this 2012 5.0 SC, it's done some 80k miles and had timing chains done at 60k accoridng to the owner (apparently has the paperwork to prove it).
Question: is this timing chains replacement and works done to fix that known problem something that will come back in another 30k miles or is the work done generally many more miles before it has to be done again ?
I'm not doing the miles I used to do hence considering moving back to petrol, but I don't want to take that chance if another £7k bill just around the corner if it has to be done every 50k.
Many thanks in advance.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #724104 7th Sep 2025 12:46pm
JCW
As long as they used the latest tensioners & guides with the hardened ‘button’ (check the part numbers used if possible) it should be good for many miles. Bear in mind the engine is notoriously tappety sounding even when there are no issues with the chains, due to the direct injection. Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #724107 7th Sep 2025 1:31pm
AlexTVR
Mines done approx 90,000 miles (not a typo 😁) since it had a new engine, apparently with the upgraded internals.
Mileages for replacement do seem to be all over the place, but 60,000 sounds quite early so why was that? Less maintenance to cause to go early?
Also, supercharger (coupler) will make a noise if worn.
Happy for you to have a poke around mine as we might not be too far part.
HTH
Alex 2010 Supercharged
Post #724109 7th Sep 2025 2:30pm
The chain was replaced as it had non hardened guides in, not because it wears out all the time...
This is the old one, above, with a lot of wear, and the new one, below, which has a hardened seat fitted.. So once it is done, it is done...
Great engine BTW, everyone should have one at some point, there won't be many 5.0 Supercharged V8's in future.... Thumbs Up Pete
-Click here for Thread-
Post #724110 7th Sep 2025 2:50pm
AndyRoo
Many thanks for that, much appreciated.
I'll try to get a look at the worksheet, I've not seen it myself so don't know who did it either.
Cheers, Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #724129 7th Sep 2025 4:05pm
AndyRoo
Just out of interest is there a point in time where this stopped being an issue, i.e. the problem was fixed at the factory ?
Post #724133 7th Sep 2025 5:43pm
I understand it was done by time of the change to the L405 so 2013 on factory fit should be good. Mike - MPx
Post #724150 7th Sep 2025 10:07pm
pcourtney
That's good to know Smile
Post #724152 7th Sep 2025 11:29pm
gt40
South Africa 2011 Range Rover Vogue SE TDV8 Zambezi Silver
Unfortunately this is not entirely correct. In 2013 a redesigned tensioner / guide system was introduced but it did not include the hardened steel button. The tensioner plunger was changed from a stepped end to a flat end and the moveable guide has a slightly widened portion to accommodate the new plunger.
The steel button design was only introduced in late 2014 after which time the guide wear problem was no longer an issue. So the 2013/2014 and some early 2015 cars do still suffer from wear on the guide but at a slower rate due the the wider plunger end.
The photos below show the original and first redesigned guides and all three tensioner designs. (Not shown is the latest guide with the steel button).
Note the bolt position of the latest tensioner design has also changed.
Post #724153 8th Sep 2025 1:05am
Superspoons
That's all great info everyone as I'm considering a 5.0SC after 3 happy years with my 4.2SC
The search continues... Gavin
https://www.youtube.com/@ChallengingClassics
Post #724161 8th Sep 2025 8:24am
AndyRoo
Hi, this is all positive news to me to be honest, it's not scaring me off.
Right now I'm procrastinating as I’m waiting to see how badly we’re going to get burned by Ms Reaves Nov statement.
So I’m going to let this opportunity slide and I’ll probably be back to the forum looking for a sub 90k 2010 to 2012 L322 5.0SC that’s had the work done.
I’ll be happy to pay a over the odds for a rust free, very clean car with all the options, that’s had the chain the works done by a reliable source.
So if anyone’s going to be in the market around then please let me know, but I will put an add in the forum so it's not a done deal. My car's perfect for me just now, but as I'll soon be retiring and not doing any long trips, the diesel might not be the right choice, DPFs etc.
Many thanks for all the feedback, great to hear it's such a well understood issue so not so scarry.
Post #724172 8th Sep 2025 11:41am
