| | SOLVED : HELP! - Tow bar wiring connectors |  |
 I picked up a second hand tow-bar on e-bay for my 2009 L322.
       |  |     | Click image to enlarge |
 It came with a 13pin plug and harness, but without a towing module.  The loom has two plugs, a fuse holder and a relay.
 The connection for one plug is easy :
 But the other plug does not correspond to the format on the Towing Module (purchased separately)
 Obviously not compatible.  I have had a browse through as many threads as I could find, but no luck so far.  I would be grateful if any one could tell me what I am missing.
 On a different note, I found this while digging a round in the boot
 Solution :
 I was watching youtube videos, and found one of a guy fitting a Britpart harness, with a totally different controller, and the plug on the harness matched mine.  A bit more research and it turns out that the harness originally came from Right Connections.  All I have to do now is find the correct controller, and sell the OEM one I bought on e-bay
   and remove the tracker.......
