Home > Technical (L405) > RR L405 Noise
BRADIAGIN
RR L405 Noise
Guys have a problem which is driving me insane, already spent £600 at a local independent and noise is still there.
So on uneven/rough roads theres a noise coming from the driver side roof-liner or the b pillar, I just cannot get to the bottom of it. The b pillar has been off, clips have been replaced, anti rattle tape been applied in certain places but this noise is still there. Also changed the driver door seal for a new one and that did not help. Then been thinking its the grab handle so tightened both screws yesterday and no difference whatsoever.
Has anyone else had any kind of noise from that area and were able to find a fix?
Post #724392 12th Sep 2025 9:31am
1JBS
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Check your roof trims not the sunroof ones but the car colour coded ones, these are stuck on with sticky foam pads, these can come unstuck over time, if they do the trim will rattle in that area as it has pins that drop into the roof bar sockets.
Post #724394 12th Sep 2025 9:41am
If your sunroof drains are broken, ie the metal pipe has rusted off this could hit parts of the inner metal sunroof frame, easy to check, search on here on checking them and see if you get two wet patches inboard of both rear wheels...
A free check you can do yourself.... Thumbs Up Pete
-Click here for Thread-
Post #724395 12th Sep 2025 10:09am
undo the grab handle screws and gently pull down the rubber trim and see if theres anything loose under the headlining. ... - .- -.
Post #724398 12th Sep 2025 11:20am
sham91
United Kingdom 2016 Range Rover Autobiography SDV8 Fuji White
Re: RR L405 Noise
I have the same exact issue and I have done the same as what you have done with replacing the clips on b pillar and the door seal (which is fixed to the body) and still have that noise lol
Did you manage to find the issue?
Post #724684 17th Sep 2025 4:12pm
