Home > Maintenance & Mods (L322) > Removal of rear Wiper/washer Motor: How To with Pics
Page 2 of 6 <123456>
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
I know, you were.
My reply was just my sarcastic sense of wit
Post #7237 14th Sep 2009 7:31pm
RRUK wrote:
I found a few places breaking range rovers
Adam do you know the part number that you are looking for ............
And what price where you quoted , could make a phone call tomorrow to someone in LR PARTS........ Thumbs Up
Post #7239 14th Sep 2009 8:13pm
I don't know the part number Mick but can easily fnd out, the price quoted was £109.71 +VAT.
Do you have a canny contact? Question Discovery 4 HSE
1993 90 Tdi
Post #7243 14th Sep 2009 10:47pm
Post #7244 15th Sep 2009 3:44am
Range Rover L322 Rear Wiper Motor
Part Number: DKD000030
What magic can you do Mick? Very Happy (the dealers all give 10% off without trying, local dealer will have one in tomorrow which I will collect Thursday if all else fails)
CWS have replied and said they do a 2nd hand one for £65 plus P&P. Not bad but who knows how long it might last? Discovery 4 HSE
1993 90 Tdi
Post #7245 15th Sep 2009 9:10am
Just my Luck ....... After saying to you, I phone up my local Dealership to speak to a good friend of mine who is the Parts Manager .... and where is he ..... Down South on a Manager's meeting for two days ......
Sorry Adam, next time i will enquire first before i jump in with both feet .......... Embarassed
Because i will need to get one as well as my rear wiper has the same problem......... Whistle
But as i suffer from L.B.S will maybe get the dealership to fit it ........ Thumbs Up
Post #7247 15th Sep 2009 9:57am
Thanks anyway Mick,
I'll let you know how easy it is to do, even if you don't do it yourself you'll know how long it SHOULD take them to do it for you. I reckon it's an hour tops. Discovery 4 HSE
1993 90 Tdi
Post #7251 15th Sep 2009 1:59pm
Mind the pic's will be watching with interest.......... Thumbs Up
Post #7254 15th Sep 2009 2:42pm
Here's the dismantling pictures:
The interior trim panel in the top tailgate has to come out. The Workshop manual doesn't say exactly how to do this. No special tools are required, just being brave and pulling hard. The pic below shows the clips. They are straight, so if you pull at an angle, you snap them (as I did on about 3) It really feels like it will all snap and break but have faith.
This picture shows the female part of the clip that the plastic attaches to. Not exactly rocket science stuff:
And here is the exposed wiper and washer motor itself. YOu might just be able to see the centre spindle which drives the wiper. Mine seems to leak water from this point, filling the plastic trim with dirty greasy washer fluid, then spilling it down the inside of the glass.
More pics to follow when I remove and refit. Discovery 4 HSE
1993 90 Tdi
Post #7276 16th Sep 2009 3:38pm
Thumbs Up Thumbs Up
Post #7277 16th Sep 2009 3:55pm
OK, Done this job now, it takes an hour max if you are taking extra special care as I did.
Tools Needed:
10mm, 12mm socket
Size 30 Torx Bit
Towels
1. Remove the interior trim as above in this thread.
2. Undo the three 10mm bolts holding the plastic spoiler top to the tailgate
3. Slide the spoiler part backwards towards the rear of the car then lift away gently as there are wires connecting to it still
4. Put the spoiler on the roof at an angle so as not to stress the wires, place some towels on your roof to avoid damage
5. Open the tailgate and undo the 2 electrical connectors and the washer pipe
6. Lift up the cap on the rear wiper and undo the 12mm nut, lift the wiper off its splines
7. Undo the 3 size 30 Torx bits holding the wiper motor in place and remove (there's no rubber grommets to remove or replace, it's dead easy)
8. Fit the new motor in the opposite way to removal
9. Replace the wiper ensuring its in a parked position (9 o'clock) and 12mm nut, push cap down firmly for water tight seal
10. Switch on ignition and activate rear wiper, kill the ignition when it is at the 6 'oclock position shown in the picture - this allows replacement of the top spoiler
11. Close top tailgate and put spoiler back in place, it has 2 white slider type grommets to place it, push back into place towards the front of the car.
12. Open tailgate and replace 3x 10mm nuts
13. Carefully replace the interior trim, start at the sides as the trim fits into the side parts first
Done! Thumbs Up
 Discovery 4 HSE
1993 90 Tdi
Post #7308 19th Sep 2009 12:57pm
Nod 1
United Kingdom 2010 Range Rover Autobiography Black 5.0 SC V8 Santorini Black
Hi There
I am new to the site and found it when searching for instructions on how to remove Tailgate Trim, as I am replacing rear wiper motor.
I have looked at it and could find no advice anywhere apart from this site. I am most grateful to you as I was puzzling how to get the trim off and as you say I will have to be brave...! as I have tried to get trim off and will perhaps have to eat more Spinach as the top trim does not seem to want to come off. One question. Is it better to start at the sides or go straight for the middle where most of the locating pins are around the motor?
ANyway thanks again for your help and this site.
Cheers
Nigel
Post #7634 6th Oct 2009 1:43pm
I started at the sides, just try and pull directly back in a straight line, if you pull down you may snap some of the plastic tags.
I thought it would be complex but its just brute force and bravery. Good luck! Discovery 4 HSE
1993 90 Tdi
Post #7637 6th Oct 2009 4:59pm
Nod 1
Thanks. I will let you know how I get on.
This is a really good site, so much information.
Thanks again
Nigel
Post #7641 6th Oct 2009 5:50pm
Nod 1
Hi
Success, just finished and as you say only takes about an hour being careful. The longest part was getting hte trim off.
I huffed and I puffed and pulled and pulled, eventually it was a quick yank that did it. But I also broke tags one on either side and the other in the middle.
Hey Ho. It now all works perfectly.
Thank you once again for the advice and tips.
Cheers
Nigel
Post #7649 7th Oct 2009 1:22pm
