![]() | Home > Technical (L405) > No sound/audio for first 30 seconds after starting ignition |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1433 ![]() ![]() |
Infotainment system starts to play up on mine when battery voltage is getting low.
andyjeffries Member Since: 20 Feb 2025 Location: Herts Posts: 16 ![]() ![]() ![]() |
I would have thought that too, but I literally had a new battery fitted a couple of weeks ago. And only when that was fitted did I realise how bad my old one was (the electric side steps would sometimes get stuck in or out, I just assumed they are flakey, but that went away and they are solid reliable since the replacement). Thanks for the thought though! 2019 Range Rover Autobiography 3.0 SDV6
Any DTC's? has it always done this or is it a new event? 2018 SE SDV8 4.4 Byron Blue |
I don’t know what DTCs are, but there’s no messages on the dashboard, if it relates to that?
Diagnostic Trouble Codes (DTCs) are standardised codes used by a vehicle's onboard computer system to identify and report problems. When something goes wrong - like a misfire, sensor failure, or emissions issue etc etc - the system stores a code, some times it triggers a dash warning light but many minor issues do not.
