![]() | Home > Maintenance & Mods (L405) > No heat |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1558 ![]() ![]() |
not sure whether a 5.0 petrol has a fuel burning heater ( and thus no diverter valve ? )
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2288 ![]() ![]() ![]() |
It defo has one as i have the remote for it and can see the gear under the bonnet Current stable:
Ok - so, does the engine get up to full temp ? V8 or else ... |
It does indeed Current stable:
Bardley Member Since: 01 Jan 2025 Location: Hertfordshire Posts: 57 ![]() ![]() ![]() |
This sounds like a blend motor/flap getting lazy.
JMKRR405 Member Since: 08 Oct 2025 Location: Houston Posts: 2 ![]() ![]() ![]() |
Jack - 2014 L405 Range Rover SC V6 Luxor metallic
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494 ![]() ![]() |
If you are getting *no* heat, it's most likely the FBH diverter valve or electric water pump.
.. 2015 Range Rover Autobiography 4.4 SDV8 |
Thanks gary - I’ve got another diverter although unbranded i think i will just swap the solenoids provided they fit.
If you read the forum, people warn against the cheap diverter valves - people have had issues with them failing. The Bosch one is around £100, genuine £200.
Tbh I did read them and some of the newer comments say you can free the old solenoid off as it’s full of crap. That is the plan a - the plan b is to put the solenoid from the cheap one in it with some rtv as the negativity i’ve seen towards the cheap ones stems from a weep coolant unless youve seen anything else?
So on my fbh woes… the fbh has been on for 5 mins and in the canine it’s blowing from the windscreen vents luke warm at best… could it still be a diverter issue? As said engine gets to temperature fine. Pr could it be the elctric pump and diverter? Current stable:
