![]() | Home > Technical (L322) > lots of error codes and no suspension |
| Joeburgess486 Member Since: 13 Sep 2025 Location: Hayling island Posts: 5
Is this a late td6 ? |
| daveaskey79 Member Since: 14 Sep 2025 Location: staffordshire Posts: 3
2006 |
If it is a td6 I had similar problems with lack of indicator lights also had flickering dash lights I replaced LCM and clocks and it fixed it but unsure if any of that would tie in with air suspension but alot of these systems talk to eachother |
Perhaps try disconnecting the instrument cluster and see if you have any different codes |
When you changed the clocks. Did they need to be coded or was it just plug and play? |
I'm not sure as I had a friend do the work I think the clocks should be plug and play |
| Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 79
As mentioned above, I would be checking the LCM. they commonly suffer from water ingress issues and can cause many spurious faults. Happened on two occasions with my Td6 during my ownership. |
| All times are GMT |
