Home > Maintenance & Mods (L322) > Replacement Key Fob
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Replacement Key Fob
Hi, just got a new key fob cover off Ali Express, supposedly zinc & leather.
Actually it's a clam sleeve that goes over the "lozenge" key fob, so if your rubber bits peeling or wearing off it goes over it so it's heavier and thicker than the original which I like.
Very substantial and quite heavy, quality is excellent and the leather inserts look well up to the job, time will tell how it holds up.
If it doesn't work as a key fob I can at least use it as a weapon.
Andy
 Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #724690 17th Sep 2025 5:06pm
robertcope
United States 2011 Range Rover HSE 5.0 V8 Ipanema Sand
Good luck. I tried some non-OEM fobs and they did not work well. The first set worked great inside the car, but wouldn't consistently lock and unlock the car remotely. The second set would do remote bits well, but inside the truck they had to be in the center console area for the truck to see them. Bought OEM keys and they work perfectly.
Post #724711 18th Sep 2025 12:49am
