Home > Maintenance & Mods (L322) > Rear toe control arm replacement
TOMC73
Hi - I am working through refreshing the suspension on my 2012 TDV8. To date, Ive replaced the rear air bags, struts and hub bushes. I am about to replace the rear toe control arms (other names track control arms / link arms), I've bought the arms, replacement nuts, bolts and washers.
I usually like to watch a video / read a guide from someone that has already done the work to see how they overcome issues like rusted components etc. but cant find anything specific on this job. Does anyone have any tips or guidance on the replacement?
Thanks
Tom
Post #724807 19th Sep 2025 4:07pm
dhallworth
It's an easy enough job to do but the steel bolts will more then likely be seized into the aluminium centre of the bush in the toe control arm. I've replaced them on 2 different cars now and have had to cut them off on both cars so ensure that you order nuts and bolts when you order the toe control arms. Thumbs Up 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #724808 19th Sep 2025 4:22pm
On both of my L332's I had to use a hacksaw to cut through the nut on the hub end joint in order to be able to remove the toe control arm. Other than that, iirc, straightforward unbolt old and bolt on new. .
Post #724809 19th Sep 2025 4:24pm
Laughing Laughing Laughing .
Post #724810 19th Sep 2025 4:26pm
