Home > Technical (L322) > Temp low on long drive
cass wrote:
Before you start replacing things it's worth checking that the temp really is low and it's not just a sensor error?
I would check the coolant temperature sensor electrical connections for possible corrosion.
Post #724779 19th Sep 2025 8:04am
Nickcoll89
United Kingdom 2011 Range Rover Vogue TDV8 Rimini Red
Anyone had this done at an Indy/specialist. What price roughly would I be looking at. Just so I don’t get ripped off with quotes.
Post #724882 21st Sep 2025 3:14pm
toby1
You say you have no pertinent fault codes so if i were you, I would replace the expansion tank (about £50) for a nice new clean one. If I can replace it in under an hour, anyone can.
Then you will clearly see the level. Bleed it as per the manual in the wiki.
I still think it is the 'stat being sticky/stuck but we shall see. 2012 Vogue TDV8 in Aintree green over sand
Post #724886 21st Sep 2025 6:02pm
Nickcoll89
I’ve probably done about 8-900 miles since I got the car now and I can see in the expansion tank when I remove the lid, the coolant level hasn’t changed at all.
Post #724887 21st Sep 2025 6:04pm
